Electronic Ignition
Posted 23 March 2017 - 08:40 PM
Will this kit fit my bog standard 1989 998.
http://www.mm-4x4.co...-kit-2721-p.asp
I believe the distributor to be the correct but not 100%
Thanks in advance.
Andy
Posted 23 March 2017 - 09:37 PM
Your 88 998 should be fitted with a Lucas 59d Distributor and if so then the 45D kit is the same so Yes as long as its a 45/59d fitted, see my post in the FAQs on the fitting from start to finish including the correct way to wire it up
Posted 23 March 2017 - 11:46 PM
Yes I have seen that thank you and it's what I will be following.
Posted 25 March 2017 - 01:49 AM
You are lucky not to have the utterly useless Ducellier distro at that age!
These timewasters should be thrown away and replaced by the appropriate Lucas.
Posted 25 March 2017 - 08:48 AM
Avoid Britpart like the plague.
Posted 25 March 2017 - 09:31 AM
Posted 25 March 2017 - 01:18 PM
You may want to look at this in the long term:
http://www.distribut...c-ignition.html
Their products are of far higher quality than most of the Mini suppliers.
Posted 25 March 2017 - 10:21 PM
For all intense purpose the britpart/accuspark and powerspark appear to be one and the same, I've not fitted any britpart one but plenty of powersparks one's and bar the odd isue of the trigger to rotor spacing they have been reliable. If you just change the trigger unit you get to keep the advance curve it came with, and they work well
