Quick Shift Gear Hard To Put In First
Posted 29 March 2017 - 07:47 PM
Posted 29 March 2017 - 08:54 PM
Is this a new fitting? If yes remove it and fit the old one.
If you have had it for a while you could well have worn out the syncros due to the reduced travel and the possibility moving the gear syncros faster than they should be moved.
Posted 29 March 2017 - 09:01 PM
Posted 29 March 2017 - 09:02 PM
Posted 29 March 2017 - 10:58 PM
They are not known as "Quick-Graunch" for nothing!
Posted 30 March 2017 - 12:00 AM
I run them and love them.
While they can shift faster and happy to do so, I just like them because the travel of the stick is more 'civilised'. One can wear out or break a box just as easy with a stock shifter
Going back to the OP, if the clutch is working OK, then it's possible the gearbox is getting tired, but I wouldn't be too fast to blame the shifter for this.
Posted 30 March 2017 - 08:50 AM
having sat in a Moke for the first time a few years ago I know why the travel reducing shifters are liked in Mokes.
Posted 30 March 2017 - 08:22 PM
Yes, I do have them in the Mokes, but, I also have them in the Minis too. I've been running these for probably about 8 years now.
Posted 30 March 2017 - 08:25 PM
Only 8 years! I binned mine 20 years ago. Or was that 21 years ago.
Posted 30 March 2017 - 08:47 PM
I put it off for a while due to the 'bad press' they'd received, but I feel the bad press is in no way at all justified. I have zero complaints about them and it often makes me wonder why the factory didn't adopt similar geometry for them in production.
Honestly, no matter how fast I have shifted with them, I have never been able to beat the Syncho. but then again, I do do full overhauls on the Gearboxes when I do them up. I've also found that they have had no effect on the life of the gearboxes either. As I say, zero complaints. Well, OK, one that they don't make one for a Moke! I have to bend the Mini one.
So, who's shifter did you have and why did you ditch it?
Posted 30 March 2017 - 09:43 PM
The 1-3 and 2-4 gates are just too close.
Oh full blown crash box. On the rod type.
Mine old Skool remote. Just again gates too close. But again I do run a remote lock out lever.
Strange as when I ran the box in the back of the GTM with a self made shifter I had no issues at all but the shift was shorter but not narrower cut down stick.
Posted 30 March 2017 - 10:53 PM
I've been using the poor man's version from Mini Spares. I haven't tried the KAD version.
I'll say that at first, I did find the Gates quite close, but it was really only a case of what I was previously used to. By the time I'd driven down the road with it that first time, I was used to it and by the time I'd driven back, loved it.
I guess with your own shifter in the GTM, you could 'adjust' it to what you like - just more work! I would think it a bit of a tricky item in the GTM since the shifter rod on the Gearbox would be pointing the wrong way.
Posted 31 March 2017 - 05:11 PM
I don't have any issues in any of the other gears and to be honest I don't mind the gears closer. So I don't really want to change the box.
Posted 31 March 2017 - 08:40 PM
