Fuel Return
16 replies to this topic
#1 Bry4ns
Bry4ns
  • 17 posts
Posted 01 April 2017 - 06:51 PM
Hi all ,
Can I put a splitter on fuel pipe return , or return fuel got to go straight back into fuel tank
Cheers bry
#2 hazpalmer14
hazpalmer14
  • 489 posts
  • Local Club: cumbria mini cruisers
Posted 01 April 2017 - 07:28 PM
You can T it into the low pressure side of the feed or weld a pipe on the tank for the return.
#3 slidehammer
slidehammer
  • 664 posts
  • Local Club: LSMOC
Posted 01 April 2017 - 08:02 PM
You don't want to weld a pipe to the fuel tank as they can explode, even more dangerous when empty than full of fuel. You can split the return but I don't know why you would want to unless you are thinking of fitting a exhaust flamer!
#4 Bry4ns
Bry4ns
  • 17 posts
Posted 01 April 2017 - 08:09 PM
Well you need a fuel line from fuel pump to regulater , then from regulater back to the t piece back round , this is right .?Attached File  image.jpeg   54.54K   40 downloads
#5 Turbo Phil
Turbo Phil
  • 1,993 posts
Posted 01 April 2017 - 10:40 PM
The plumbing will work ok, but the pump won't work in that position. It's gravity fed, so needs to be mounted level or below the bottom of the tank.
Phil.
#6 Bry4ns
Bry4ns
  • 17 posts
Posted 02 April 2017 - 04:51 AM
Thanks Phil, appreciated will move it
Cheers bry
#7 mini13
mini13
  • 2,902 posts
Posted 03 April 2017 - 09:29 AM
Really easy solution is to use an mpi tank with the pump inside it. Dead neat!
#8 Bry4ns
Bry4ns
  • 17 posts
Posted 03 April 2017 - 05:56 PM
Yeah thought that but was advised the pumps fail quite frequent , that was from mini specialist !
#9 mini13
mini13
  • 2,902 posts
Posted 03 April 2017 - 07:33 PM
That sounds like balls to me, they are a generic pump, basically the same as any modern in tank pump,
#10 Bry4ns
Bry4ns
  • 17 posts
Posted 04 April 2017 - 07:35 PM
Prob is balls as lots of "do this way" try this "
#11 Bry4ns
Bry4ns
  • 17 posts
Posted 18 April 2017 - 10:56 AM
So fuel pump is in , regulator is in , car turns over , do I need a relay for the fuel pump or is it ok to come off ignition
Cheers again
Bry
#12 mini13
mini13
  • 2,902 posts
Posted 18 April 2017 - 11:08 AM
I would add a relay,
#13 Mervyn
Mervyn
  • 243 posts
Posted 18 April 2017 - 12:16 PM
100% wire it via a relay. Also look at fitting an inertia switch to kill the pump in the event of an accident
Merv
#14 Bry4ns
Bry4ns
  • 17 posts
Posted 18 April 2017 - 12:34 PM
Cheers guys , can I just use a relay from ignition switch then to
fuel pump.?
#15 Mervyn
Mervyn
  • 243 posts
Posted 18 April 2017 - 01:03 PM
I guess you could, though you'd have to wire an inline fuse , would be nearer run from a switched source at the fusebox. Ensure it remains live during cranking.
Mini Spares
