I've got these bits which I'm not really sure the value of them are. Pics will come. First up is a set of innocenti conrods with some +60 21251 pistons, no rings mind. They look alright but I'm not 100% sure. Next is a 1330 block, bores seem OK but I haven't really had a proper look. It'd definitely do with a hone at least. And then there's the gearbox. All in bits, diff is there with the crown wheel but no pinion.. layshaft etc all looks OK. I've not touched a gearbox before so I couldn't say if it's missing anything else. Case number is DAM 5626 which I believe is A plus? I'll get the photos up in a bit
Innocenti Rods, 1330 Block And G Box Valuation
PetePinnington
, Apr 01 2017 07:58 PM
3 replies to this topic
Posted 01 April 2017 - 07:58 PM
Posted 03 April 2017 - 02:39 PM
Rods are A series not INNO, INNO rods don't have the big counter balance on the big end... the cross bar is common... £40 the set is what I charge for them.
block, £50 if that, as it's a 1330 and unless you know it has, probably hasn't been offset bored so effectively can only go to 73.5mm without being linered...
Gearbox in bits < £35
Edited by Guess-Works.com, 03 April 2017 - 02:40 PM.
Posted 11 April 2017 - 09:52 PM
Completely forgot about this lot. Thanks for confirming they are not inno rods guess works. Wouldn't want to sell them as something they are not! Will be listing these bits up for sale shortly 👍
