I really need some help with this. I failed to take pictures before I tore out the section of the floor under the petrol tank. I have everything back in place except that blasted bracket. I do not know where it goes for sure and before I weld in the new one I made I'd really like to know. What is confusing me is there is a hole in the tank in the same general area but it does not come close being in line with the hole in the bracket. And, when I place the old bracket in what I think is the correct location the strap is too short to reach the bracket by about 1" or 25 mm. Maybe that is how it should be to allow the bolt to draw the strap tight. Does the bracket butt tight against the flange on the tank?
And on top of this, when I did several searches looking for anything that would help I discovered what is called a left hand tank support bracket. Heritage part # 14A6867. If this car had one then the previous repair person eliminated it. Is it required?
I have included some pictures for your reference. Any help will be greatly appreciated. Thanks in advance.
Bill
