Advice Needed On New Panels
Posted 07 April 2017 - 07:13 PM
I have stripped the mini down but just waiting for the bracket to lift the engine out. I have started looking at the rust and wanted some advice. There is rust appearing round the wings and scuttle panel, should I just get a new front end. Both footwells have alot of rust. Someone had tried to repair them with a patch and used bathroom silicone to hide the terrible job they did. The toeboard is rusting toward the bottom and where the subframe mounts are. The left rear wheel arch has also got a patch on with silicone for extra strength. The right side has two holes all the way through. I'm not sure how I would get to these spots. The boot has a rust hole in the right hand corner and has been patched In the left corner too. Could I have some advice on what to do on each of these problems, I can attach pictures if needed.
Thank you
Posted 08 April 2017 - 09:41 PM
Pictures always help...
I had rust around my rear sub frame mounts, a rusty battery box, small holes under spare wheel and a crusty valance seem. All could have been patched individually, but decided to replace the whole boot floor.
Same with arches, I had holes in the top, and you can get that part on its own, but there was no was to weld it in properly (full arches are seem welded/crimped) to just bought full arches
Toeboard might be straight forward as its pretty much a flat panel, so should be simple to patch
footwells can be easily replaced, I ended up doing the whole floor due to patches of rust
wings/scuttle, not really done them yet, but again should be easy to replace
have a look at my project:
http://www.theminifo...i-cooper/page-2
Q
Posted 08 April 2017 - 09:58 PM
Yep, attach pictures (use Photobucket) but by the sounds of it a lot of work ahead.
Posted 09 April 2017 - 02:17 PM
Posted 09 April 2017 - 02:56 PM
All of my Mini related problems involve handing over cold hard cash to Minispares ;)
Posted 09 April 2017 - 03:18 PM
I think we can all relate to that particular ailment.
Posted 09 April 2017 - 05:58 PM
They will be soothing my problems tomorrow morning ;)
