Many parts from a mini 30 project.
Shell, engine, front subframe, etc.
Link to some photos: https://flic.kr/s/aHskTeyMpA
More than welcome to ask what is available and I will try and see what I have.
Engine - 998cc
Its all dismantled but all parts should be there, i can include all the ancillaries. carb and standard air filter too. radiator, and gear linkage etc.
£200 for the lot.
Shell
I was planning on replacing the whole front end, so front panel, wings and scuttle are cut out. The RH door step is also cut out. Doors and boot are there, no bonnet thought (that got used for welding practice)
The bottom has all been stripped of muck and the sound deadening stuff inside on the floor has been removed.
Looks like there is rust hole in one of the rear bins.
V5 and vin plate are present.
£100
Seats and door cards - sold
Majority of parts are not stored at my house (it’s still at my parents house) so please be patient if I cant get back to you straight away, I will try my best to do asap.
Location is GU24 postcode. Pickup only for the larger items or possible drop off if very local to either GU24 or GU14 postcodes.
May be able to send smaller items at extra cost.
Also number of parts for sale, mainly new - will add these to relevant sale sections soon.
New Genuine heritage panels
RH inner wing with A panel - £170
LH inner wing with A panel - £170
RH door step -£50
LH door step - £50
Scuttle panel - £100
Front subframe (front mount rad) (coat of hamerite) - £400
Rear subframe (coats of hamerite) (partly built) price just for subframe - £370
Gaz lowered shocks (full set) - £140
Superfin drums - SOLD
hi-los - SOLD
Coil springs (2 springs are branded minitastic with rubber cups. Other two have no branding so unsure of brand? - £120
Specialist components rear billet hubs with bearings and studs - £80
Tim gauge volt - £20
Tim gauge vac (used) - £20 - includes spacer adapter to wire this up and piping
Tim gauge amp - £15
K&N air filter - £40
Radius arms - £45 each
Tie rods - £25
1.5 degree lower arms - £25
Used non-genuine rear subframe - £30
Brake pipes for rear subframe - £25
Edited by mini_dan, 08 May 2017 - 07:14 PM.
