Slight Play In New Wheel Bearings
Posted 16 April 2017 - 11:30 AM
Posted 16 April 2017 - 11:32 AM
Posted 16 April 2017 - 11:33 AM
Posted 16 April 2017 - 11:43 AM
Posted 16 April 2017 - 12:28 PM
I think this figure is 270nm and on to next slot. I say go to the next slot and see how it feels.My torque wrench goes to 210nm, think as my mini is 1989 that figure needed is nearer 250nm. So I tightened to 210nm then with a scaffolding bar cranked around to next split pin opening on the nut. Cant be far off the required tightness! Sure some will frown at this method! Maybe go to next slot on the nut?
Posted 16 April 2017 - 01:29 PM
Edited by 1314cc, 16 April 2017 - 03:40 PM.
Posted 16 April 2017 - 03:41 PM
Edited by 1314cc, 16 April 2017 - 04:10 PM.
Posted 16 April 2017 - 08:15 PM
If you've tightened them on the bench to as much as 100 ft / lb and you can feel play, then something's not right with the assembly somewhere, be it bearings or hub.
Tightening to 210 nm and then going to the next split pin hole would easily be 270 nm+. Any more would be over tightening and in any case, if you are getting play at 210 nm, as above, there's an issue.
More and more these days, I find the hubs are worn.
Posted 16 April 2017 - 08:57 PM
Posted 17 April 2017 - 07:17 PM
Which brand of bearing are they, genuine or otherwise, and were they supplied as a matched pair with spacer? And did you keep each bearing inner with its own outer? (The cone angle may vary slightly).
Posted 17 April 2017 - 07:30 PM
Think I'll start with drive flange and split collar. It really is only the slightest of play though,hardly anything
If you're feeling play without having had the weight of the car on it, it's not likely to be the flange & collar.
Posted 17 April 2017 - 07:47 PM
They were Quinton and hazel and yes they were paired to race and had a new spacer. Done both sides and same amount of tiny play in both
Edited by 1314cc, 17 April 2017 - 07:55 PM.
Posted 17 April 2017 - 07:53 PM
Posted 17 April 2017 - 08:34 PM
