Slight Play In New Wheel Bearings
#16
Posted 17 April 2017 - 09:21 PM
#17
Posted 18 April 2017 - 05:55 AM
#18
Posted 18 April 2017 - 06:39 AM
Yeah that's your problem! Rubbish bearings!
Hi Cian, I bought some delphi balljoints from you recently after struggling to set the crap ones from minimine. Have you used qh bearings before? Thought they were an ok ish brand. Looks like I'll be ordering some timken!
#19
Posted 18 April 2017 - 07:03 AM
#20
Posted 18 April 2017 - 07:53 AM
I recently got an old stock of qh front wheel bearings the bearings themselves where timken but that stock has sold, im assuming that modern day qh are probably just using the same unbranded bearings everyone else is peddling, was there any brand markings on them? I will be getting another stock of front timkens in the next few days they will be £40 currently I have lots of interest but I can certainly hold one over for you, I have lots of rear timkens tooHi Cian, I bought some delphi balljoints from you recently after struggling to set the crap ones from minimine. Have you used qh bearings before? Thought they were an ok ish brand. Looks like I'll be ordering some timken!Yeah that's your problem! Rubbish bearings!
Edited by cian, 18 April 2017 - 07:54 AM.
#21
Posted 18 April 2017 - 09:41 AM
#22
Posted 18 April 2017 - 10:49 AM
As to the original problem, the bearings were most likely Timkens, properly selected and paired, which may suggest that the hub casting is worn, most likely by previous outer rings having rotated. The next step towards proving what is the exact problem would be to accurately measure the thickness of the rib in the hub which spaces the two bearings apart. Not the easiest thing to measure because of where it is, and it needs some kind of micrometer, not just a vernier.
There is also the possibility that the apparently genuine bearings are in fact counterfeit, as the counterfeiters are tending to replicate the proper packaging nowadays. Sometimes silly spelling mistakes give them away. Last time I looked the Timken web site and those of other mainstream bearing manufacturers carried warnings about the problem.
It is getting ever more difficult to ensure that anything you buy is the genuine article these days. It is mostly beyond the resources of Trading Standards, although they do their best and quite often seize loads of dangerous electrical goods and such like.
Maybe after Brexit there will be more UK manufacturing, which will help.
#23
Posted 18 April 2017 - 02:42 PM
#24
Posted 19 April 2017 - 11:37 AM
#25
Posted 19 April 2017 - 02:28 PM
Good luck! Please keep us informed of your findings as it helps others.[/quote
Another thing that slipped my mind was when I removed both hubs the inner seals seemed to be fitted backwards?? So the flat edge was flush with bearing. I've never had any bearing work done and have owned the car for most if it's 28 years! Is this correct or not? ]
#26
Posted 19 April 2017 - 03:49 PM
#27
Posted 19 April 2017 - 04:49 PM
#28
Posted 19 April 2017 - 09:02 PM
Here's a cross section drawing that may help NOTE that the seals do not go all the way down to the bearings
At various times in production, they did fit spacers for the seals, seems to have been during the late 70's and early 80's.
Edited by Moke Spider, 19 April 2017 - 09:20 PM.
#29
Posted 20 April 2017 - 06:30 AM
#30
Posted 22 April 2017 - 05:45 PM
