Slight Play In New Wheel Bearings
1314cc
, Apr 16 2017 11:30 AM
37 replies to this topic
#31
Posted 22 April 2017 - 06:22 PM
The putting isn't ideal but not the cause of play
#32
Posted 22 April 2017 - 06:43 PM
Might replace cv whilst all apart though, and hang on for your timkens!
#33
Posted 22 April 2017 - 08:16 PM
Yeap, the CV is cactus.
#34
Posted 22 April 2017 - 08:38 PM
Yeah be good to change em now! I've got a few cv joints and guna hound my supplier for timkens asap
#35
Posted 30 April 2017 - 07:55 AM
Fitted new cv joint but still slight play so have now ordered some timken bearings. Think I'll use Moke Spiders guide and measure up the hub for wear. Hopefully it's just cheap bearings giving me grief!
#36
Posted 01 May 2017 - 03:17 PM
When you get the new cvs slide the drive flange on and check the fit
#37
Posted 14 May 2017 - 05:58 PM
Finally got rid of the play. Get straight to the point in a hope it may help someone else one day! Just removed one of the thinnest shims from Upper balljoint. I couldn't really see any movement beforehand but guess it just wasn't quite tight enough. Live and you learn! What a bell end! Just glad to be finally able to move on to the next problem!!
#38
Posted 14 May 2017 - 09:26 PM
Are you very sure that your ball joint is still moving freely throughout its travel? If it is tight, that is far more hazardous than slightly loose wheel bearings.
