Progress has been a little slower than usual recently, mainly due to our baby girl arriving on the 20th Sept! The last couple of weeks have been a tad hectic as those of you with your own can imagine I'm sure!
I managed to steal a few hours today however and popped up the unit to try and get a few odd jobs ticked off the ever growing to-do list.
Starting in the boot - I was able to save the original boot floor to wheel arch stiffeners which is satisfying. Although they'd not exactly break the bank to buy new, it is a nice change to use original metal where possible. I took them to work a while back and gave them the treatment in the blasting cabinet and they came up great. I bolted them to the boot floor through the rear subframe mount holes to get them exactly in the right position and ensure the holes line up well, but both the N/S and O/S stiffeners needed a little felling to get a good fit. They mainly just needed the outer most flange to be dressed forward to meet the wheel arch. Here's the N/S on just after being welded in...
As you can see, once I'd sprayed weld-thru over the whole area and zinc primer on the underside of the stiffener, we seam welded along the three boot floor flanges and along the top where it mates with the wheel arch. The other flanges were spot welded originally but I don't have the correct arms to work around the rear panel, so we had to plug weld them. Once it was all ground down and painted I think it looks pretty good! Especially considering it'll be hidden behind the fuel tank.
And the O/S
Another job I managed to get ticked off the list was to remove the flash rush on the inside of the battery box and spray it with zinc primer. Again, I'm pretty happy with the finish.
Edited by SamG, 07 October 2017 - 06:35 PM.
