The last thing I had to get sorted before the roof could be fitted was to make a few repairs to the gutters, weld up the existing Mk4-on drain slots on the front and rear panels and then cut the age appropriate drain slots in their place. this is the first repair I tackled and the top of the O/S a-pillar...
Little cardboard template
A view of the metal piece from the top
Here it is all ground down, really happy with how it turned out. You can also see I squared up the edge of the gutter to make it easier to fit the new piece next.
The process for getting the gutters fixed up was exactly the same for each corner, so I'll just show the clearest pictures of each stage. Here's the O/S front with the little repair piece made from 1mm steel rolled around a screw driver shanks. Agricultural but I think it worked OK.
And the next piece to complete the curve. I don't have any pictures of the middle of the welding process as I was on a roll and didnt want to stop. As all the steel was fresh it welded really nicely and I managed to find the Goldilocks setting on Ellis' new R-Tech 180 welder, so that helped. After welding in the the patches it was a case of using a cutting disc in and angle grinder to shape it and get the right profile. Easy for the outside but very tricky on the inside of the gutter, one slip and it's a whole world of hurt.
A view from the top and the front of the completed curve.
