Carb Conversion Mot Emissions
Posted 20 April 2017 - 12:37 AM
I have a 1996 spi which I've just started stripping down and cutting out all the rust. When i get round to rebuilding it i would like to convert it to run on carbs.
I've read a few different posts saying you can put an older engine into a newer car, change the engine number on the v5 and get the emissions test based on the age of the engine.
Can anyone confirm once and for all that if i put an older carbed engine into the 96 shell will the emissions test be based on the car or the older engine?
I would like to know before i get too invested in this car whether i should just sell it on and buy an older one.
Many thanks
Posted 24 April 2017 - 08:02 AM
If anyone knows for sure how the emissions test laws work that would be very helpful!!
Posted 24 April 2017 - 08:35 AM
Posted 24 April 2017 - 08:38 AM
http://www.ukmot.com...-Spark-Ignition
the emissions test will be based on whichever is older - the engine or the car
the difficulty would be proving the engine is older, to make it bullet proof I would get a copy of the V5 that the donor engine came from, this would prove the age. You would also need to change the engine number on your V5
Posted 24 April 2017 - 10:05 AM
Posted 24 April 2017 - 02:51 PM
To answer the OP's question they would still have to take the original emissions test because they are rebuilding the original engine not swapping to an older carb engine.
Posted 24 April 2017 - 03:21 PM
As far as I'm aware the tester gets the emissions standard via the DVLA recording system. Ivan is correct, it would be up to you to satisfy the DVLA and get the V5 record changed. From previous topics, they ask for a letter from the garage that fitted the new engine . Maybe you could ask your MoT tester for a written inspection report well before the test is due, especially if they are familiar with Minis.
Posted 24 April 2017 - 04:40 PM
That's not what the op says, rebuilding the 96 body but fitting an "older carbed engine", not fitting carbs to the 96 engine.
Edited by CityEPete, 24 April 2017 - 04:41 PM.
Posted 24 April 2017 - 05:54 PM
This is very helpful thanks guys! How would you prove to the tester that the car is fitted with an older engine? Is a printout of the 'Guess Works' website for that engine acceptable?
Posted 25 April 2017 - 09:25 AM
Posted 25 April 2017 - 09:39 AM
ah I see, I missed that bit and just saw "When i get round to rebuilding it i would like to convert it to run on carbs" which I assumed was talking about just the engine.
Posted 25 April 2017 - 05:21 PM
Also depens on what side the mot'er got out of bed and what mood he's in. my mot station one guy a 4x4 bloke and a hater of minis mind and the other a ex mini guy, both good guy's but there own opinions.
Posted 26 April 2017 - 07:54 AM
Posted 26 April 2017 - 11:07 AM
As I said (unless a tester wants to correct me?) the emissions results go to VOSA as part of recording the test, so need to be below what's on the system for your car. Unless the tester gets "confused" and puts the probe up the wrong exhaust pipe .
You need to convince the DVLA to change the engine on the V5 to change the emissions standard before you tip up for an MoT. They'll want evidence from an "expert" who's seen what's under your bonnet.
Posted 26 April 2017 - 02:54 PM
