Should a wet solid mounted front frame have the steel spacer mounted?? Or is it only the dry one?? I know that the wet frame is half an inch higher so im guessing not?? Am i right??
Front Subframe
flobo
, Apr 22 2017 06:55 PM
2 replies to this topic
Posted 22 April 2017 - 06:55 PM
Posted 22 April 2017 - 07:02 PM
No spacers on towers for wet subframe only on dry.
http://www.somerford...page=page&id=68
"When fitting the front subframe to the car, bear in mind that an hydro
subframe does not need spacers between the towers and the shell as dry ones
need. This happens because hydro subframes are taller than dry subframes,
hence not needing them."
Edited by mab01uk, 22 April 2017 - 07:07 PM.
Posted 23 April 2017 - 01:41 PM
Thx i thought so :)
