Specs
Austin Mini Mayfair 1985
998cc with Stage one kit fitted.
HS4 Non-Waxstat carb
Hi,
I am having real trouble getting my new ignition system/rebuilt carb setup,
I have installed a new Powerspark electronic dizzy, HT leads, Coil and Plugs aswell as rebuilding the HS4 carb with a genuine SU kit (I replaced the needle with a new like for like as i accidentally damaged the original)
I set the timing using a strobe to TDC
Set the HS4 jet to '12 sides' down from the top position on the adjustment nut
Wound up both the fast idling and the standard idle screws so neither were making contact.
The engine fires perfectly on the first turn of the key every time, but is idling about 2000RPM.
So I raise the jet adjustment nut, this lowers the revs but still only to about 1200RPM, however at this position it is unable to recover after acceleration.
So I 'devance' the timing to lower the revs but this causes misfires with i can't tweak with the mixture nut
Has anyone any ideas on where i am going wrong?
