Hey Everyone,
I've recently brought a 1998 Rover Mini MPI.
However the person who had it before me has messed with the suspension somewhat.
Its probably also helpful to know that im running 13 inch wheels with 165/65 13 tires on them all round.
In a poor attempt to lower it at some point there is now a few problems, and me being unfamiliar with the type of suspension i have no idea where to start.
First off the N/S Rear sits loads higher that the rest of the wheels (by about 20mm, 90-100mm from the wheel arch)
The O/S Rear Sits about right, or at least what i assume is right (75mm ish from the wheel arch to the top of the tire)
Now thats not really the problem.
The big problem is with the front of the car, both sides sit about 20mm from the top of the tire to the arches! Causing alot of noise when going over bumps and even when turning (where the wheel touches the arch) and im also assuming that it is hitting the bumpstops every ten seconds.
The shocks on the back are standard and the front ones are GMAX (which i think are used to lower by 20mm??)
I am also not sure if it is running HILOs or anything of that nature, i do know that is isn't running a coil spring conversion though.
any help would be appreciated on what to do to set it all up correctly, weather its best to buy all new parts and return what i dont need if i already have it ect. then i can get it tracked and have some proper fun in it :)
