Spi
Posted 23 April 2017 - 09:05 AM
Posted 24 April 2017 - 08:56 AM
Try a new crank sensor. I have just put the engine back in my '95 spi and managed to cut through the crank sensor wires on the front panel. Engine turned over but no fuel or sparks. A couple of hours of head scratching and checking connections later i found the cut wire, joined it, and it fired straight up. Just got to get a new sensor now!
With regards to the immobiliser if you don't have the alarm key fob chances are there is no immobiliser as i have the same black box behind the dash but no alarm or immobiliser. The other halfs Mpi has alarm/immobiliser and the immobiliser kicks in after the key has been removed (within a minute or so) and if you try to start it without pressing the unlock button the engine won't even turn over.
Posted 24 April 2017 - 10:08 AM
Posted 25 April 2017 - 03:05 PM
Look for item no. 7 It seems that it is the part used in lieu of the alarm as a link.
https://www.rimmerbr...m--i-GRID000451
