Checking Shell Dimensions
No replies to this topic
#1 lsdweb
lsdweb
  • 65 posts
Posted 24 April 2017 - 01:02 PM
Hi All
I've got a shell that has a 'new' floor and cross member - the rest is also pretty good but no front end.
The quality of welding in some parts is pretty poor (not a huge problem as we will clean off and redo this). I'm concerned that if the welding is poor, then maybe the fit of the new floor may not be as good as it should be.  Are there measurements / dimensions on here that I can use to check everything is ok? I've done a search but can't find anything. There were bracing bars across the door openings and between the b pillars when I bought it.
I don't want to start fitting a cage to find out the thing isn't square!
Wyn
Edited by lsdweb, 24 April 2017 - 01:03 PM.
