Hi all I just wondering can a 99 Mini Cooper with multi point fuel injection be remapped is there a big gain and do I need to do any other things to engine it's just standard at minute
Re Map
Jasethepace
, Apr 28 2017 09:50 PM
6 replies to this topic
Posted 28 April 2017 - 09:50 PM
Posted 28 April 2017 - 09:56 PM
Not really worth it on normally aspirated engines as the gains are very small.
Posted 28 April 2017 - 10:05 PM
Would I gain more by changing exhaust and fitting k&n is there any other small things I could do without getting two deep in engine?
Edited by Jasethepace, 28 April 2017 - 10:08 PM.
Posted 28 April 2017 - 10:11 PM
That would certainly give you more noise.Would I gain more by changing exhaust and fitting k&n is there any other small things I could do without getting two deep in engine?
Save up a little more and change the head. That will give you a real increase in performance.
Edited by Northernpower, 28 April 2017 - 10:12 PM.
Posted 28 April 2017 - 10:54 PM
Just the head or would have to put a cam in it also
Posted 29 April 2017 - 06:29 AM
The ecu can't be remapped
Posted 29 April 2017 - 08:25 AM
It depends where you want to stop. A head change will certainly give you an increase in performance but to fully benefit you need a cam change as well.Just the head or would have to put a cam in it also
