As above is the diameter of an RC40 1 3/4 or 1 7/8?
Rc40 Diameter?
Posted 29 April 2017 - 08:39 PM
Posted 29 April 2017 - 08:43 PM
1.75" OD
Posted 29 April 2017 - 08:46 PM
Posted 29 April 2017 - 09:00 PM
Posted 29 April 2017 - 09:02 PM
And this answer really helps clearing things up.Both.
All depends on wich one you buy, they even have 2" rc40's now .
Edited by Dusky, 29 April 2017 - 09:02 PM.
Posted 29 April 2017 - 09:11 PM
Nick: Really, since minispares don't specify any sizing I assume they are all the same diameter.
Dusky: Are you sure? I can see some on minisqpares where just the end pipe is 2"
Posted 29 April 2017 - 09:46 PM
Mine is 2 inch, if you look halfway down this page youll see how I modified it http://www.theminifo...today/page-439. On the following page you'll see the completed job. I put the flexi in because no matter how much I tightened it up, the Y piece was moving on the downpipes and letting air in and as a result affecting the lambda reading.As above is the diameter of an RC40 1 3/4 or 1 7/8?
Posted 29 April 2017 - 10:12 PM
Both.
Both ??????
I've always taken it to be 1.75" -http://www.minispare...px|Back to shop
Does the diameter change on the bends?
minisilverbullet: i've got a unused RC40 Classic (twin box) exhaust in the garage -i will measure it for you tomorrow morning.
Posted 29 April 2017 - 11:16 PM
Posted 29 April 2017 - 11:22 PM
And also is the measurement the ID or the OD? They do not say.
Craig what exact info do you need? I can measure mine tomorrow.
But I would say it is too small for yours.
It is on the limit for mine.
Posted 29 April 2017 - 11:31 PM
I will actually only need the CAT back section.
Looking at my exhaust today it is a bit of a mess.
1 7/8 down pipe - to a 1 3/4 link pipe with flex joint (using a reducer) - into the CAT ( which hangs low) - 1 3/4 two box RC40 CAT back section.
Not ideal but I need to keep the flexi joint section as it has the flange for the CAT.
What i need is a single box CAT back system. Options are a RC40 1 3/4 or a Maniflow 1 7/8.
I have to say the info the actual diameter on almost all suppliers pages is pretty sparse.
Even with the manifold system - I am not sure if the the section from the CAT to the silencer is 1 7/8 or is it it is just the rear section that is 1 7/8. http://www.maniflow....ct&product=1144
