In 2006/2007, I had a hell of a time due to a bad batch of "genuine" cones that kept collapsing on my Mini. I ended up with the red spot competition ones, which worked well.
Ten years on, a different Mini, but apparently the same problem. I got genuine cones (and Hi-Los) fitted back in January but only recently started using the car properly again. The drivers side was low, so I wound up the Hi-Lo until I could get 4 fingers above the wheel, but it settled back down again - twice. Now I've ended up with the drivers side Hi-Lo significantly more extended than the passenger side. I reckon the cone has at least partially collapsed.
Has anyone else experienced recent poor quality genuine cones? I was looking to make the car feel close to original, hence trying the genuine ones again...
Cheers for any help and advice.
- Rob
