I have a 1992 carb cooper and snapped the fan switch witch is on the sandwitch plate ywl10010 I believe it is and there 70 pounds was wondering if the transducer in later minis will do the same thing or any help really but 70 for a switch is a bit steep :/
Fan Switch On Carb Cooper
Kevdee
, Apr 30 2017 09:05 PM
4 replies to this topic
Posted 30 April 2017 - 09:05 PM
Posted 30 April 2017 - 09:31 PM
I think it's a sensor in the sandwich plate. The plug is inside the nearside wing. You can wire a switch to that and mount it somewhere, I put mine on the little panel low down by the drivers door and just ran the auxiliary fan and switched on the second fan as and when needed.
Posted 30 April 2017 - 10:21 PM
I managed to break it too - and I have a switch in the same place as MrP. They must be very fragile it only took the sling to slip when I was lifting the engine out
Posted 01 May 2017 - 06:03 AM
Cheers I was hopeing to put back as was but cheaper than 70
Posted 01 May 2017 - 12:29 PM
I replaced mine as it was not working when I bought my RSP. The trouble is it is very eager to switch the fan on at stupidly low temperatures.
