Can Too Little Rear Braking Be As Bad As Too Much?
Posted 01 May 2017 - 06:31 PM
But can too little rear braking be as bad as too much?
Posted 01 May 2017 - 06:35 PM
Posted 01 May 2017 - 06:51 PM
Having some "swapping end issues" since doing a load of work on the car so I guess it's got to be suspension set up issue
Posted 01 May 2017 - 06:58 PM
Posted 01 May 2017 - 07:02 PM
Edited by mini-geek, 01 May 2017 - 07:03 PM.
Posted 01 May 2017 - 07:14 PM
are the rear wheels toeing in ?
if they toe out for any reason (clipped kerb etc) , handling will get nasty , esp with back end stepping out
radius arm adjusters can move sometimes (depending on make / quality)
also check tyre pressures , lower on back can make back swing out a bit to start a spin (oversteer)
also what tyres / condition , diesel / oil on road can also liven things up
Edited by sledgehammer, 01 May 2017 - 07:15 PM.
Posted 01 May 2017 - 07:50 PM
Posted 01 May 2017 - 07:59 PM
Posted 01 May 2017 - 08:56 PM
Corner weights are good well as close as I can get them..
With you in the car?
Posted 02 May 2017 - 11:18 AM
