Indicator Stalk Broken
1 reply to this topic
#1 Bradl
Bradl
  • 11 posts
Posted 07 May 2017 - 05:40 PM
Hi I have a problem with my Mini in were the left indicator stalk has separated into two parts the small end piece and the one with all the symbols for horn and indicators but when i click them together and turn on the ignition the horn is on constantly. Also the main problem is when you try to operate the horn is doesn't spring back like it normally should what do you think i should do to fix this? thank you .
#2 minimans
minimans
  • 411 posts
Posted 07 May 2017 - 06:00 PM
When the end came off the return spring went Wheee! It's on the floor somewhere or out the window.........................
