My 1.3 SPI rover mini sidewalk will start perfectly when cold and not been run for a while. It idles nicely and also runs nice and smooth with no problems.
However after a small bit of running when i turn off the engine, the car will not start again unless left for an hour to allow the engine to cool. It turns over and also fires up for a split second but then wont start. It can be bump started.
I think it could be to do with the engine being fed too much fuel when hot since it needs a lot of fuel to start when cold.
Does anyone know anything about problems such as this? and where to start looking for the problem? Could it be engine management fault? Air filter? vacuum pipe fault?(although i dont think its this after checking)
Any help appreciated!
