K&n Filter In The Box Noisy Under Acceleration
Best Answer eric.sen , 04 August 2017 - 12:16 PM
Some news....
I had a sump guard, took it off, it was doing resonance chamber,
now the car under acceleration is lot quiet.
:D
Go to the full post
10 replies to this topic
#1 eric.sen
eric.sen
  • 113 posts
Posted 16 May 2017 - 04:13 PM
Hello,
I have a K&N filter in the genuine air filter box, but the noise is very present in the car under acceleration :X
Is it normal ?
The car always got this filter since 10 years / 10.000 kilométers (I'm from France)
I clean the filter but it is still noisy.
Any advice please ? :shy:
#2 RooBoonix
RooBoonix
  • 1,224 posts
Posted 16 May 2017 - 05:43 PM
Are all the clips present which hold the 2 parts of the airbox together?
#3 eric.sen
eric.sen
  • 113 posts
Posted 17 May 2017 - 12:33 PM
Yes all the 4 clips are there and the 3 screws also
#4 eric.sen
eric.sen
  • 113 posts
But very Noisy Under acceleration actually
#5 Nu2mini
Nu2mini
  • 442 posts
Posted 18 May 2017 - 07:43 AM
How have you diagnosed the problem to be the filter ??
What type of noise is it ?
How different does it sound to a Blown exaust or manifold leak ??
Are there any other symptoms ?
Is the car running well ?
#6 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 May 2017 - 10:44 AM
Has the noise started since you put the K&N filter in the housing or has it become noisy over time?
I found one of my exhaust bolts on the head was loose causing a lot of noice, could be that? also make sure filter housing is flat and secure
#7 eric.sen
eric.sen
  • 113 posts
Posted 19 May 2017 - 02:13 PM
Hello Nu2mini and Jamesquintin
Maybe you are wright because I didn't notice that noise before,
But the noise is only Under full acceleration
I know that I had to repair the braided part Under the manifold just before the Cat.
If the braided part is used could it be that noise ?
#8 Steve220
Steve220
  • 4,893 posts
  • Local Club: BMC
Posted 19 May 2017 - 03:37 PM
install the old filter and see if it is the same. If not, then it's the filter. The K&N replacement filter is a little noisier, but shouldn't be too much.
#9 eric.sen
eric.sen
  • 113 posts
Posted 20 May 2017 - 02:02 PM
Yes I will try to found my old genuine air filter.
#10 eric.sen
eric.sen
  • 113 posts
Posted 24 May 2017 - 08:56 AM
Look to the car today, the bolts to the manifold and the head are OK and the filter box also....
#11 eric.sen
eric.sen
  • 113 posts
Posted 04 August 2017 - 12:16 PM   Best Answer
Some news....
:D
