Is this simple to do? I believe my float is either stuck or broke? I have a full tank of fuel, but it tells me I'm empty on the dial.
Posted 25 May 2017 - 09:37 AM
Posted 25 May 2017 - 10:12 AM
Posted 25 May 2017 - 10:44 AM
You should be able to see it from the neck of the tank - LED torch and it will shine inside, at the very least you will see the arm the floats attached too.
Posted 25 May 2017 - 04:22 PM
Edited by Rapidmini59, 25 May 2017 - 04:55 PM.
Posted 25 May 2017 - 04:59 PM
It is very easy to do. Just tap the fixing ring to "screw" it off its location. Then remove and replace - best to do the seal at the same time. Just a note, make sure you empty the tank to below the sender or you will fill your boot with fuel!
Andy
PS. And if you do do it, please be very careful with an open fuel tank!
Posted 25 May 2017 - 05:49 PM
Posted 26 May 2017 - 01:19 AM
A long piece of wire with a hook on it, drop it down the neck of the fuel tank and you'll be able to grab the sender unit float arm. Turn the key on and lift the wire up and down while watching fuel guage through back window.
Posted 26 May 2017 - 10:11 AM
Posted 26 May 2017 - 02:36 PM
All sorted now. The fuel had seeped into the float causing it to sink. Therefore, I fitted a new fuel sender unit.
Thanks everyone for the comments regarding my question, they really helped.
Posted 26 May 2017 - 04:41 PM
Posted 28 May 2017 - 02:23 PM
Has it got a rubber ring on the new one? I fitted one and within a week the rubber ring had swollen up and made the float sink! I took the ring off and it's fine again now without it.
It did! It had a new rubber ring round the float and I instantly thought, "that shouldn't be there as it would potentially make it sink", lol! However, going from your message above I'm now glad I removed it prior to fitting!!
The bonuses of Mini forums, hey!
Edited by RichMPiBlue, 28 May 2017 - 02:23 PM.
Posted 28 May 2017 - 06:30 PM
Edited by CityEPete, 28 May 2017 - 06:32 PM.
Posted 29 May 2017 - 09:19 PM
Posted 30 May 2017 - 01:15 PM
Posted 30 May 2017 - 07:31 PM
It's fine without it, the arm doesn't have enough rotation to hit the top and bottom of the tank.
That's good!
