Disconnecting The Petrol Tank Sender Float?
#16
Posted 30 May 2017 - 10:18 PM
#17
Posted 31 May 2017 - 09:55 AM
The original floats are brass without any rubber ring too, earlier smaller tank with a badly adjusted arm and brass float would have various noises possible!
#18
Posted 05 July 2017 - 10:11 PM
I've just struggled to fit a new one and it not work.....
Now I have a full tank of fuel to try and empty out and start all over again....
Edited by toplessmini, 05 July 2017 - 10:12 PM.
#19
Posted 05 July 2017 - 10:25 PM
Are you sure you've got an MPI one with the dog leg in?Is there a nak to fitting one in an MPI?
#20
Posted 05 July 2017 - 10:33 PM
The one removed is identical to the one newly installed in it shape and length. It was very tricky getting the end that is secured to the tank to sit flat. I have shorted the two wires to check the needle rises in the dash and all is ok.
Its definitely an MPI one, as the last one did work.....
Edited by toplessmini, 06 July 2017 - 08:32 PM.
#21
Posted 23 July 2017 - 10:04 PM
#22
Posted 24 July 2017 - 09:20 AM
#23
Posted 24 July 2017 - 04:37 PM
#24
Posted 25 July 2017 - 06:30 PM
