Wheel Offset
Posted 28 May 2017 - 01:16 PM
I'm planning on converting from 12" to 10" wheels using the Minispares brake conversion kit with there own brand calipers. I've seen some wheels I like they are 4.5" wide with ET35 offset I currently have no arch extensions will these wheels fit also without arch extensions.. Thanks in advance Graham.
Posted 28 May 2017 - 02:14 PM
I`m not sure if this will help but worth a look i guess
www.1010tires.com/Tools/Wheel-Offset-Calculator
you will probably have to copy and paste as computers are not my thing :)
Edited by absx2, 28 May 2017 - 02:17 PM.
Posted 28 May 2017 - 03:01 PM
Posted 29 May 2017 - 01:05 AM
They're essentially the same dimensions as the original 4.5" Cooper S steel wheels so should be fine without arches.
Posted 29 May 2017 - 06:24 AM
Thanks that's exactly what I wanted to here. Good man.They're essentially the same dimensions as the original 4.5" Cooper S steel wheels so should be fine without arches.
Posted 02 June 2017 - 09:42 PM
Yes, they will fit without arch extensions.
Posted 02 June 2017 - 10:09 PM
Nice one thanks.
