Hi all I'm new to mini's & I'm getting my 1994 35th anniversary car next week.
It requires a few jobs including repairs to the dash as it has a walnut Finnish dash fitted but it's cracking. So I'll change it possibly for a different one but was wondering if it's possible to change the current 2 dial to 3 dial dash? Also what do I need to get or do?
Any help or advice would be great!
2 Dial To 3 Dial Conversation
Chris M
, May 28 2017 04:17 PM
7 replies to this topic
Posted 28 May 2017 - 04:17 PM
Posted 28 May 2017 - 04:24 PM
If you have a wood dash then all you need is a set of clocks. The wires are already there.
If your going standard you will need clocks, plastic surround, mounting bracket and dash liners.
Posted 28 May 2017 - 04:25 PM
But be carefull you dont get mpi clocks. I think they are different.
Posted 28 May 2017 - 07:51 PM
Hi all I'm new to mini's & get my 1994 35th anniversary next.
It needs a few jobs doing & amongst them is to repair or replace the dash.
It currently has a 2 dial dash but would like to convert it to a 3 dial set up.
Is this possible? Do I need another wiring loom?
Or I did here that the tachometer wire may be loose behind the dash somewhere?
Any help or guidance would be great.
Posted 28 May 2017 - 09:26 PM
Edited by THE ANORAK, 29 May 2017 - 05:10 PM.
Posted 29 May 2017 - 07:34 AM
Yes sorry.
I didn't think the original one had gone on here. By the that time it was too late.
Thanks for you reply to the original post
Posted 29 May 2017 - 07:36 AM
Do you know what year or type of clocks I'll be ok with ie what about a set from a SPI?
Posted 29 May 2017 - 09:10 AM
You probably have electronic ignition on that car so make sure the 3 clocks set have an RVC tachometer (just 1 spade and 1 bullet connection) otherwise the older type will not work.
