Alas these parts have been sat in my workshop for years now, I don't have the space time or funds to complete this project and so all these bits have got to go!
All these bits are currently stored in a warm dry environment in TW20. Send me a PM to come take a look! Collection preferred for the weighty stuff!
DISCLAIMER: It's been years since I touched any of these bits so I have little idea if I'm pricing them correctly (or even naming them right!) - I'm relying on honesty if I'm fleecing myself or indeed taking the p*ss! If I've listed something wrong just let me know!
ALL PARTS NOT INCLUSIVE OF POSTAGE :) buy more than one bit to save yourself some bob!
Brand new parts labelled as such, never used. Reconditioned parts labelled as such. Rusty parts also honestly labelled!
List of parts followed by pictures:
Swiftune SW5-07 Camshaft, Standard Cam Followers, Oil Pump, Road Double Valve springs - BRAND NEW - £175
Chrome Rocker Cover, cork gasket - BRAND NEW - £15
1275 Water Pump + Gasket, no bypass drilled out, BRAND NEW - £8
4 core radiator (uprated one?) + mount plate - BRAND NEW - £80
1275 silicone hose kit, blue - BRAND NEW - £40
Full headlining in anthracite/slate grey - includes all pillars and visor covers - BRAND NEW - £60
Fuel Pump + spacer, BRAND NEW - £25
HIF44 Carb + mount plate, disassembled and cleaned ready for rebuild + REBUILD KIT - £80
Oil filter housing + 4 filters - CLEANED AND REPAINTED - £10
Inlet Manifold, heated, appears to have been gently ported - £25
Alternator Pulley - CLEANED AND REPAINTED - £5
Thermostat housing and sandwich plate - CLEANED - £15
Clutch housing breather - CLEANED AND REPAINTED - £5
Valve spring compressor tool, BRAND NEW - £15
Timing cover and plate - REPAINTED - £20
Full set of valves - 4* 29.5 race valves, 4*35.7 race valves, 4*valve spring caps (all minispares parts) - BRAND NEW -£40
Head stud, nut and washer kit (9stud) - BRAND NEW - £10
1275 gasket set - (honestly have no idea which gaskets are included but picture should reveal all!) £10
1275 Block, Camshaft, 8 push rods, 4 pistons + conrods, clutch housing and cover, Crankshaft pulley fitted with toothed timing gear for digital ignition - Block labelled 12HE72, Crank labelled 11AKJGSB and CAM6232. - Make me an offer on these? I also have the gearbox from the same block but cant get pictures of it at the moment.
12G940 Head - Surface rust on the mating face, in need of a skim and valve seats recut. Believe this is the larger valve style head? Has been ported a touch. - £80
IN ADDITION TO THESE PARTS, NOT PICTURED (but hopefully to follow!)
Gearbox to match the above block
Duplex timing gear set
Digital ignition kit (the name of which completely escapes me)
Another 19g940 head, possibly the small valve variant?
LINK TO PICTURES
LINK TO PICTURES
If you got this far, thanks for reading!
Z
Edited by Zik, 11 June 2017 - 11:23 AM.
