Points Or Electronic Igintion
46 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 12 June 2017 - 12:23 PM
Just take the cap off and see whether there are points inside. It is that easy, and as quick as posting the question, far less waiting for possibly irrelevant replies.
#17 Readers14
Readers14
  • 408 posts
Posted 12 June 2017 - 01:28 PM
 Read my opening post:-
"So, was going to check the points, but can't tell if I have any.
When I took the dizzy cap off, I didn't see any points, just the rotor arm.
Are they hidden behind a plate?"
I was unsure whether I had points or not.
#18 gazza82
gazza82
  • 2,915 posts
  • Local Club: TMF+
Posted 12 June 2017 - 04:44 PM
Pictures here are both points dizzies .. http://www.theminifo...ibutor-is-this/
#19 Readers14
Readers14
  • 408 posts
Posted 12 June 2017 - 05:01 PM
Thanks.
Mines definitely an electronic ignition type, the dizzy looks nothing like the ones in the link.
New dizzy cap, rotor arm, ignition module & Intermotor coil ordered.
Let's see if that cures the problem!
#20 nicklouse
  • 17,931 posts
Posted 12 June 2017 - 05:27 PM
make sure it is the correct coil for the dizzy. they are not all the same.
#21 panky
panky
  • 1,776 posts
  • Local Club: Northwest Casual Classics
Posted 12 June 2017 - 06:19 PM
And change one thing at a time so you can isolate the problem.
#22 Readers14
Readers14
  • 408 posts
Posted 12 June 2017 - 07:07 PM
Followed the links on the Minispares shop.
Ordered this http://www.minispare...|Back to search
#23 nicklouse
  • 17,931 posts
Posted 12 June 2017 - 07:32 PM
but what is your dizzy? and are you sure you have ballasted set up?
#24 Readers14
Readers14
  • 408 posts
Posted 12 June 2017 - 07:37 PM
Yeah, thinking about it that maybe the wrong one.
Electronic dizzy with the ignition module should be non ballast, right?
#25 Readers14
Readers14
  • 408 posts
Posted 21 June 2017 - 11:26 AM
Had time last night to start removing the ignition parts for inspection.
First up was the ignition module:-
Correct me if I'm wrong, but those connections have seen better days!!!
#26 nicklouse
  • 17,931 posts
Posted 21 June 2017 - 11:52 AM
this is the coil you need
http://www.minispare...CL143.aspx|Back to search
#27 cal844
cal844
  • 9,485 posts
  • Local Club: TFMOC
Posted 21 June 2017 - 01:18 PM
yes they have, however still salvageable just try give them a scrape up with a small electrical screwdriver
#28 Readers14
Readers14
  • 408 posts
Posted 21 June 2017 - 01:26 PM
I have new ignition module and connector to the coil. So they will be replaced anyway.
#29 Ethel
  • 25,401 posts
Posted 21 June 2017 - 02:40 PM
Sounds like you have a 65dm4. The dizzy cap screws on and the metal body is in 2 parts hiding the electronics inside. Google yourself some piccies , there's no mistaking them - and use the correct coil GCL143 or equivalent for a 65 dizzy.
#30 Readers14
Readers14
  • 408 posts
Posted 21 June 2017 - 05:14 PM
What GCL143 equivalents are available?
