Hi
I have a few small patches of rust on the bottom of my passenger door. I've sanded them down and used some por 15 metal prep on them. Do you think I need to cut and weld in new patches?
Removing Rust On Door Edge
Chesty2925
, Jun 14 2017 02:30 PM
6 replies to this topic
Posted 14 June 2017 - 02:30 PM
Posted 14 June 2017 - 02:32 PM
If it's in the door skin then it'll be worse on the inside of the door. Have you looked behind your door card?
Posted 14 June 2017 - 02:39 PM
I recently changed the door cards and it didn't look too bad behind them. I'll take another look
Posted 14 June 2017 - 02:43 PM
Posted 14 June 2017 - 03:15 PM
You need to look inside the door. That looks pretty bad. A few options available, but if you want longevity, I'd be taking off the old door skin, repair the door and re spray. Alternatively you could probably cut that part out and replace with a section of the repair panel available from m-machine.
Posted 14 June 2017 - 03:54 PM
Posted 15 June 2017 - 11:05 AM
You'd still need to look inside the door to see the severity. I'd imagine it's pretty rotten.
