These are the readings, 1 being nearest to radiator
1. 159 PSI
2. 132 PSI
3. 132 PSI
4. 159 PSI
The car runs fine though I am getting a puff of smoke on
Overrun when I have just put my foot down. Also the exhaust has a lot of black soot on it but the plugs seemed ok.
Could there be an issue with the head gasket between 1&2
Or is this a piston ring nightmare.
Compression Readings For 1275Gt
bevyid31
, Jun 22 2017 12:49 PM
5 replies to this topic
Posted 22 June 2017 - 12:49 PM
Posted 22 June 2017 - 01:34 PM
do a wet/oil test see what happens
Posted 23 June 2017 - 04:49 PM
Is this a standard 1275GT motor or has it been modified?
The lower readings on 2 & 3 could suggest head gasket is not quite sealing fully between two centre cylinders.
Posted 25 June 2017 - 10:08 PM
Yes the engine is standard, I have been told though with the readings I am getting that if it was the head then those readings would be lower though.
Posted 26 June 2017 - 11:41 AM
Very likely a valve job needed. Perform a cylinder leakage yes to confirm.
Ac
Ac
Posted 26 June 2017 - 04:51 PM
Thanks I have just ordered a leakage tester so will see what happens
