Rear Light Problems
Posted 22 June 2017 - 09:39 PM
indicators work
hazzards work
brake lights work
BUT
when i switch the lights on with ignition off the headlights come on but the rear dont
when i turn the ignition on the rear come on
if i switch the lights off with ignition on the rears stay on the fronts dont
i,ve tried numerous wire swapping but i cant get it right
HELP PLZ
Posted 23 June 2017 - 07:44 AM
Edited by Mervyn, 23 June 2017 - 07:45 AM.
Posted 23 June 2017 - 06:00 PM
checked earths,both headlamp and switch have original block connecters on
confused
Posted 23 June 2017 - 06:42 PM
First, you seem to have a feed into the lighting system from the ignition switch. That is not normal, so we can assume it is due to a fault or crossed wire, as the car was not built like that. The indicators work so we can probably rule them out. The ignition switch energises the brake light switch, which has been known to short, so that provides a possible feed point into the lighting system. Also, it feeds the reverse light switch. Does the reverse light work normally?
I suspect that there are multiple faults, as no single fault could account for all the symptoms. Not uncommon, or expensive, just annoyingly difficult to fathom out. Possibly the brake switch has shorted (or just badly adjusted, it is press to open, pedal up) and the ignition feeds the brake lights which have no earth so the current goes back through the tail lights to earth through the head/side lights, but that does not precisely account for the symptoms.
There is not going to be an instant diagnosis on this one. The best way forward is to disconnect all front lights at the bullet connectors behind the bonnet catch, and all rear lights at the bullet connectors in the boot. Do not disconnect the black fuel tank earth. Disconnect the brake light switch. Then put the rear light cluster earths (black) back in, ensuring that they are clean, and the side/tail, which will be red. Try the lights and report back, or if ok, put the next thing in which should be the brake lights (green/pink). Continue until you find something that does not work.
Posted 24 June 2017 - 05:26 PM
cheers i will try all that tomorrow
Posted 24 June 2017 - 07:27 PM
Hi Chadd,
Are you talking about the minus maxi - maybe something missing with the earth at the rear of the car when you changed the lights
Regards
Posted 25 June 2017 - 09:04 AM
yes its the minusHi Chadd,
Regards
i,ve got on rear lights r/h
red/black
white/green
green/purple
red/yellow
same on l/h
but a black aswell
then spliced out the middle of loom connect r/h l/h
i have a black which goes to into a red/white which goes to heated screen
and a yellow which goes intored/green which goes to back light
Posted 25 June 2017 - 01:14 PM
connected the red sidelight wires switched on lights,nothing
switched ignition on and i have rear lights
but if i then switch of lights rears stay on until i turn ignition off
Posted 25 June 2017 - 02:49 PM
I never realised that it was a GRP bodied car. That makes it interesting! No conductive bodyshell.
Where are the earths all connected?
Posted 25 June 2017 - 05:51 PM
Posted 26 June 2017 - 12:25 PM
It does sort of seem like missing earths and sneak circuits but the evidence so far is inconclusive. Maybe go visually through the harness, checking that the correct colour of wire is on each terminal?
