Hi,
I've been investigating a rare clunking noise coming from the driver's side (LHD). I've gone through the usual checks, ball joints, hub, all kinds of bushings/brackets, engine mounts, exhaust mountings and all seem mostly fine.
I have some play in the steering tie rod end on that side along with a clunking noise when I quickly turn the wheel side-to-side. However, I've noticed that the axle has been grinding away on the subframe. What can cause this?
Picture taken on full right lock: https://goo.gl/photo...HdCKc9q4MD1kj56 you can clearly see the circular grind along with the shavings on the subframe. How can I fix this? What has gone wrong here?
Edited by AeroNotix, 25 June 2017 - 01:33 PM.
