I'm having a problem getting my carb to maintain its mixture for more than a couple of days.
After removing and cleaning the carb, then tuning it for a correct mixture, it runs great for a day or two until it gradually becomes too rich to run properly. I eventually have to start backing the mixture screw out over time until it's all the way out. I've ruled out ignition or any other items that would cause it to continually run poorly. Again, it resets after I take the carb off and drain it, and then slowly gets worse over a few days.
So far I've replace the float, needle, needle and seat, and dashpot oil, and made sure the piston moves smoothely. Any ideas on what could cause it to enrich over a few days?
Edited by Dfitzy, 25 June 2017 - 09:17 PM.
