Front Hub
Best Answer Ruth's Mini , 26 June 2017 - 11:59 AM
thanks everyone - will try the angle iron approach, failing that will attempt to split the nut
regards
Go to the full post
7 replies to this topic
#1 Ruth's Mini
Ruth's Mini
  • 101 posts
Posted 25 June 2017 - 10:49 PM
Trying to remove the CV joint nut for separation from the hub and cannot get it to budge.
Am I missing something here or is it possible that after 50+ years it's just on super tight?
thanks in advance
#2 Ruth's Mini
Ruth's Mini
  • 101 posts
Posted 25 June 2017 - 10:53 PM
tried to post a picture but can't get it to upload
#3 nicklouse
  • 17,929 posts
Posted 25 June 2017 - 10:58 PM
wheel on the ground and a big long lever and maybe some one to press on the brakes.
#4 Ruth's Mini
Ruth's Mini
  • 101 posts
Posted 26 June 2017 - 09:35 AM
thanks, it's off the car and in a vice but this does answer my question so I guess heat and patience is the answer
#5 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 26 June 2017 - 10:09 AM
If you can get hold of an impact gun you may find it will move more easily.
#6 nicklouse
  • 17,929 posts
Posted 26 June 2017 - 10:24 AM
depends on what you plan on keeping.
don't like heat that close to the bearings and seals.
nut splitter. hammer and drift/chisel or as above. rattle gun and some clever clamping in a vise.
#7 Spider
  • 13,888 posts
Posted 26 June 2017 - 10:28 AM
I have a piece of 3" x 3" Angle Iron, about 18" long with 2 holes drilled in it for 2 studs.
I clamp up the Angle Iron in the vice and then bolt up the drive flange to the Angle Iron via the studs.
Easy ;D
#8 Ruth's Mini
Ruth's Mini
  • 101 posts
Posted 26 June 2017 - 11:59 AM   Best Answer
regards
