Dashboard Top Rail Repairs
5 replies to this topic
#1 Stu1961
Stu1961
  • 625 posts
  • Local Club: Still Looking
Posted 02 July 2017 - 07:32 PM
Hi everyone,
Looking for a bit of advice, my top rail is going to be re-covered with new vinyl, however the original covering is damaged there are three separate areas where the covering needs to be filled/sanded down biggest is about 1/2" x 2" the underlying molded foam is sound and intact, just wondering if anyone had repaired one before and if so how you went about it.
Ideally what is required is a flexible type filler that to some extent remains pliable, surface finish and colour is not that important as once done will be covered.
Any advice much appreciated
Stuart
#2 nordicmini
nordicmini
  • 293 posts
Posted 03 July 2017 - 08:49 AM
expanding foam will do it from screwfix
#3 Chris.Williams
Chris.Williams
  • 679 posts
Posted 03 July 2017 - 09:21 AM
What he said ⬆️
#4 Stu1961
Stu1961
  • 625 posts
Posted 03 July 2017 - 07:59 PM
Thanks Gents, will give it a go
Stuart
#5 Mervyn
Mervyn
  • 256 posts
Posted 03 July 2017 - 10:28 PM
Four tips:
Wet the surface before applying it as it will grab a lot better to the existing foam
Use half as much as you think you need
Leave it at least 24hrs then trim it with a new sharp knife then sand it down
Wear gloves
Merv
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 04 July 2017 - 05:12 AM
Four tips:
Wear gloves
Merv
Plus one on wearing gloves; it's very messy stuff if it gets out of hand.
Edited by Northernpower, 04 July 2017 - 05:12 AM.
