Hi guys, weekend before last I finally bit the bullet after fantasizing about a mini since I passed my test, so this is 7 years in the making. A quick rundown of what I "know" about the car: 1989 Mini Thirty, supposedly with a 1275 engine, big valve head, stainless DTM exhaust, one piece liftoff fibreglass front end, etc. etc.
I've had it just over a week, and spent more time taking it to bits than driving it (the joys of owning a classic car ), and I've got a few simple problems that neither myself (mechanically speaking, an absolute novice) nor my dad can figure out...
When I bought the car from someone who shall remain nameless for reasons that will become clear, it was overheating like a MF (120+ degrees C). Of course, on the quick test drive this wasn't a problem and I never noticed, but driving 100 miles home from Buckingham, I had to stop twice to let it cool down. The heater matrix was leaking, no big deal, so that has been bypassed until I take it out to repair/replace it. There was a small 80W electric fan on the rad, with no mechanical fan, and the rad had been moved away and downwards with some dodgy homemade brackets. To cut a long story short, I ordered an 11 blade fan, made some brackets and unbodged the bodge to restore the mechanical fan. Turns out they moved the rad to allow the front end to fit, so we've chopped the rad cap off and soldered a brass cap plate on, and fitted a land rover expansion tank just to get it running while I get a radiator that fits (or have one made if it comes to it) and a stainless expansion tank to fit under the wing.
Now it will drive without overheating, but it still runs at about 85 degrees in the warm weather we've been having recently, with the thermostat completely removed, and will creep past 100 when sat in traffic if I don't keep my eye on it. The fan blows through the rad into the wing (I thought it should suck from the wing and through the rad, and blow over the engine but having never owned one, I don't know), which is driveable but still too hot considering the lack of stat.
Setting the carb is just about impossible, the idle mixture screw is currently almost all the way in to try and smooth the idle, the timing is not properly set as we can't turn the distributor enough for the revs to begin to fall to find the peak to back off from (hope that makes sense, like I said, I'm not a mechanic ). The colourtune and plug colours all show the mixture not bad if not a tad rich, it's not pinking, so it's about as close as we can get it using the tools and information from the car's sound and behaviour, however, the idle is still lumpy even when warm (although much improved on when I first got it), it's bogging under acceleration under about 2.5-3k revs, and it drinks like a fish (although I suspect a small fuel leak, it intermittently greets you with a lovely smell of petrol in the cab).
I will post some pictures soon, and I am trying to keep as detailed a diary as I can given my limited mechanical knowledge, hopefully some of you Mini Jedi masters can come to my aid
Cheers,
Phil.
