Is there anything different between a manual and auto bodyshell. Could I buy a bare shell that's been restored but was originally an auto... and put everything from my manual donor onto it. Or will I have to start welding in brackets and cutting holes etc.
Manual Vs Auto
auroan
, Jul 14 2017 01:07 PM
1 reply to this topic
Posted 14 July 2017 - 01:07 PM
Posted 14 July 2017 - 02:09 PM
if you are rebuilding the shell with parts from a different car then the car needs to keep the ID of the shell. you can not use the ID from the parts to rebuild your car you need to use a brand new shell.
you will need to cut a hole in the center tunnel to suit the shifter mechanism.
Edited by nicklouse, 14 July 2017 - 02:09 PM.
