Where Do I Get An Spi Inlet Manifold?
#16
Posted 29 October 2017 - 07:30 AM
#17
Posted 29 October 2017 - 08:32 AM
Bit obvious but stainless ones were v difficult to bend right, brass was much easier.
I'll also post the ebay link later to where I got the pipes from incase anyone wants to give it a go themselves, I would think most SPIs will have this issue.
#18
Posted 29 October 2017 - 10:33 PM
FS
#19
Posted 31 October 2017 - 10:17 PM
As promised here's where I got the pipe from...I got 500mm lengths of both and if you don't mess up the bending you'd get two inlet manifolds worth out of that length...or one :)
Stainless Steel - 15.87mm/0.625" T304 (could be polished if wanted)
https://www.ebay.co....872.m2749.l2649
Brass - 15.8mm
The Brass pipe is 'looser' than the steel.
#20
Posted 01 November 2017 - 02:35 PM
#21
Posted 06 November 2017 - 12:06 PM
Great work Pops!
What did you use to bend the pipes? It looks amazing!
MA
#22
Posted 06 November 2017 - 02:18 PM
lead.jpg 63.14K 2 downloads
The pipe bending, especially with stainless was tough. First attempt flattened the steel on the big bend. We have a set of copper pipe benders for heating pipes. Have different profiles for different pipe sizes and bends but ended up using a 22mm bender set (15mm was too small) and packed it out with some lead.Then it was a matter of being careful to keep everything inline and not going too far when bending.
Also have pipe flaring tools to get the end right.
