I am looking for a valuation on my hill climber. I got in touch with previous owner a long time ago and he if you ever want to sell it let me know. What do you all think it is worth on the open market. It no longer has a MSA log book. I just used it a few times to go around Curborough for a laugh. It would come with DVLA log book I think is 84.
Cooling
2 Core Aluminium Rad
14 Blade Yellow Plastic Fan
Braided Top Hose
Overflow Hose Is Silicone
There Is No Heater Control Valve, Straight Take Off With Silicone Hose To A Bulk Head Connector
Silicone Hose From Bottom Hose To Bulk Head Connector
Van Type Heater Unit In Car, It Retains the Demisting Part
Fuel System
Rectangular Ally Tank Approx 20 Litres In Boot
Solid State Fuel Pump
Fuel Regulator And Filter
Braided Hose / Inside Line Along Tunnel
45 DHLA Dellorto
Twin Cable Linage
K & N Air Filter
Working Choke System
Fuel Pressure Gauge
6 Inch Cast Ally Inlet Manifold
Battery Box Type: Air Box Welded In
Exhaust
LCB Large Core Manifold (Not A Budget One, Maybe A Maniflow, Early One)
Wrapped With Heat Shield Fabric And Stainless Steel Tie Wraps
RC40 Exhaust Twin Box
Emission Control
Breather On Timing Cover
Ally Rocker Box With Breather Take Off
Breather On Fly Wheel Cover
Silicone Hose To Ally Catch Tank With Sight Tube
Starting And Charging
High Torque Starter From MED Powerlite
Standard Output Alternator
Odyssey Race Battery
Fibreglass Battery Box Inside Cab
Kill Switch Next To Tunnel With External Pull
Starter Button With Fuel Pump And Ignition Switches
Power Cable Goes Through Bulk Head With Proper Block (Not A Gromit)
Starter Solenoid With Push Switch Mounted On Front Sub Frame
Fork Lift truck Jump Starting Plug
Distributor
8mm Unipart Plug Leads
Sports Coil Not Ballasted
Dizzy No Vacuum Advance
Clutch
Orange Pressure Plate
Lighten Back Plate
Lighten Fly Wheel
Clutch 6 Paddle
Uprated Clutch Arm MED
Plastic Master Cylinder
Gear Box
Refurbished 3.6 Final Drive, X-Pin Differential, Windage/Baffle Tray All By Guess Works
Rod Change
The Floor Pan Is For Cast Remote
Gear Shift Late Mini Std
Std Drop Gears
Drive Shafts
Standard CV Joint
Rubber Bump Stops
Braking
7.9 Discs Vented And Grooved
Mini Sport Callipers 4 Pots Black
S Master Cylinder
Single Line Set Up
All Stainless Steel Braided Hoses Or Solid Copper Inside Lines
Rear Brake Bias Valve WP Located Behind Drivers Seat
Electric Pressure Switch For Brake Lights
Mini Fins With Spacer On The Rear
Fly Off Hand Brake
Suspension
Long Track Rod Ends
Rose Jointed Tie Bars
Adjustable Bottom Arms
Adjustable Ride Height All Round
Mini Spare Adjustable Castor / Camber Bracket On The Rear
Competition Rubber Donuts All Round
Adjustable Krypton Gas Spax Shocks All Round
Front Sub Frame Welded And Gusseted
Two Towing Eyes
Two Bolts Per Tower
Two Front Sub Frame Brace Bars As Using Fibreglass Front End
Rear Sub Frame, Rear C Section Removed And Box Section To Replace It
One Rear Towing Strap
13 Inch Mountney Steering Wheel
Steering Lock Still Active
Orange Poly Bushes On Rear Sub Frame
Front Sub Frame Solid Mounted
Bodywork
The Sub Frames Set Square To Each Other
Glass Windscreen, Polycarb In The Rest, Slider In Driver’s Door
Ally Door Skins With Small Ally Tube To Make It Rigid
Fibreglass Boot Lid
Two Door Mirrors
Small Black Plastic Wheel Arches Std
The Rear Wheel Arches Have Been Turned Up Into The Bodywork As In The Vizzard Book
Seat Mounted To Rails That Run From Tunnel To Sill
All The Pedals Sit In Line
Sparco Sprint V Seat
4 Point Harness RRS Wide Type Date 2018
Rollcentre 6 Point Cage With Fixed Diagonal And Harness Bar And Bolt In Door Bars
Internal Fuse Box
Koso Electronic Speedo
Race Tech Oil Pressure Gauge
Smith Rev Counter
Race Tech Fuel Pressure Gauge
Water Temp Gauge
Minilight Wheels, 6 Inch
Bridgestone 175/50 R13 Potenza (7.5mm Tread)
Single Wiper Arm
No Rear Valance
Flat Ally Boot Floor
Engine
A Series Block Board To 1398 Using Fiesta Piston, We Got About 20 Different Piston Sets In so Found The Best At That Time
Copper S Crank (This Is Done By Modifying The Thrust Washers)
Copper S Rods
Steel Centre Main Strap
Steel Shim Head Gasket
Heavy Duty Flywheel Bolt And Key Washer MED
Billeted Oil Filter Head Kit MED
1.5 Roller Rocker Assembly MED
MED Cylinder Head 35.7 Inlet, 31 Exhaust, 24.8 cc Chamber With Piper Double Springs
Duplex Vernier Timing Chain
Adjustable Pressure Release Valve
Cam 296 Kent Cam
22lbs Oil Warning Light Switch
