Having Engine Issue's
engine electrical
4 replies to this topic
#1 Bethandavies77
Bethandavies77
    Starting My Mini Up
  • 1 posts
Posted 21 July 2017 - 06:34 PM
Hi
I have a 1986 Austin Mini that I am having trouble with. About a month ago it had a new 998 a+ engine and it has been running really well but recently it has started spluttering a lot. The petrol tank and carb have been cleaned out and it has new fuel lines but we still cannot figure out what is wrong with it. It will turn over and sound like it wants to fire and as soon as it does it just dies, even when the car is running it just wont rev or go fast enough to keep itself going.
If any of you have had this same problem it would be great it you could give any advice.
Edited by Bethandavies77, 21 July 2017 - 06:36 PM.
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 21 July 2017 - 06:39 PM
could be anything. Check the ignition side of things first and go from there. Points, condenser, cap etc
#3 mk1leg
mk1leg
  • 9,341 posts
Posted 21 July 2017 - 06:50 PM
was it a New engine or a 2nd hand rebuild engine
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 21 July 2017 - 07:12 PM
changed the heddle in the carb got the right carb for the engine,modded any other parts , like exhaust dizzy. needs rolling roading
#5 nicklouse
  • 17,937 posts
Posted 21 July 2017 - 07:21 PM
check what has changed from when it was running well.
you say new engine. New or just new to you? have you discussed it with the builder have you set it up to their requirements?
Also tagged with one or more of these keywords: engine, electrical
