so i was using my corded dremel earlier and it just died, tried the fuse but not that and so does have any ideas if it can be fixed and if not what would be a good replacement? another dremel or any other alternatives possibly cheaper?
Dremel Stopped Working
Posted 22 July 2017 - 05:39 PM
Posted 22 July 2017 - 05:44 PM
I've had two do the same
Lidl sometimes do a version for about £30, not tried one but their tools are usually pretty good.
Posted 22 July 2017 - 06:20 PM
Posted 22 July 2017 - 06:28 PM
i wouldnt even say mine was old either is them failing quite common and no way to fix them
Posted 22 July 2017 - 06:35 PM
I had mine to bits, no signs of any wires broken, motor brushes fine, just wont go
Posted 22 July 2017 - 07:17 PM
yep done exactly the same, nothing broken and hardly any wear and tear and surprisingly little dust inside too
Posted 22 July 2017 - 08:26 PM
ah found the fault broken wire in the motor , looks like a common fault and so il buy something different next time
Posted 22 July 2017 - 09:38 PM
We bought one from Lidl, it broke on first use. The spindle lock jammed so you couldn't change tools. Took it back and got the money back as it felt really cheap too.
I also have one of the old Dremels, it's got to be ~10 years old. It's not had an easy life but still works fine. If you're looking for one, maybe try picking up one of the older models 2nd hand.
Edited by Icey, 22 July 2017 - 09:39 PM.
Posted 22 July 2017 - 10:37 PM
Yeah my mates did that too
+1
Posted 23 July 2017 - 02:51 AM
I have an ancient one, pushing 20 years. It is Craftsman branded, corded, single speed and it is still running fine. My friend has burned up two with variable speed in no time flat.
Edited by xrocketengineer, 26 July 2017 - 05:48 PM.
Posted 23 July 2017 - 10:51 AM
I've just killed mine, but it has had a seriously hard life working on the Midas. I replaced it with one the same thanks to some vouchers so it doesn't owe me much. I did think about buying a different brand item, but having seen some of the cheaper accessories available, I stuck with what i know. There's probably better ones on the market, but I didn't have the time to do any research. Let's see how long this one lasts...
Posted 31 July 2017 - 12:49 PM
Send it on to Big Clive for a diagnosis: https://www.youtube....rGRuWd0JQMx76qA
Posted 31 July 2017 - 06:01 PM
Posted 01 August 2017 - 03:31 PM
well i got a cheap one off amazon, and yes you can tell its cheaper, only used it once so far and is doing the job and so shall see how long it lasts
Posted 07 August 2017 - 04:54 PM
I decided to see if I could fix the Dremel today so I had it to bits. Checked the readings across the windings and found one just under 25 ohms but the other one was zero. after a bit of prodding and tugging at the terminals this happened
The wire must have been broken inside the terminal, the pic was taken after I'd pulled the connector out of the housing.
So I soldered a short piece of copper wire onto the end.
Placed the lengthened wire over the groove in the housing and pushed the terminal back in. There's a groove in the terminal that grips the wire as you push it in - a bit like a phone wire connection. The result was the same 25ish ohms across both windings so I built it back up, plugged it in and bingo it works
Edited by panky, 07 August 2017 - 05:14 PM.
