Boot Floor & Heel Board Replacement
3 replies to this topic
#1 Luapno
Luapno
  • Just Joined
  • 13 posts
Posted 25 July 2017 - 10:38 PM
I am just about to embark on a restoration on a 1967 Mk2.
The car is stripped down the shell and ready to start work. I am starting at the back and working forward so, my first question is:-
I need to replace the boot floor, heel board and floor etc etc. The heel board is a pile of rust so I don't have any sub frame datum points to install the new panels. Does anyone have any tips for lining everything up correctly. I had thought of making a jig from the sub frame but not sure how good that will be.
All ideas welcome. Thanks in advance
Paul
#2 jamesquintin
jamesquintin
  • 1,017 posts
Posted 26 July 2017 - 01:58 PM
Replace the whole floor as one assembly with the hell board... Hopefully the rear subframe mounts are ok to help with alignment?
#3 Luapno
Luapno
  • Just Joined
  • 13 posts
Posted 26 July 2017 - 02:20 PM
I wasn't aware you could get the floor with the heel board already fitted I will have a look.
The rear mounted are OK so will have to be careful with the sequence of replacement
Thanks for the advice
Paul
#4 greenwheels
greenwheels
  • 672 posts
  • Local Club: Mini Fixers
Posted 26 July 2017 - 03:39 PM
These dimensions might help: -
http://mk1-performan...al_drop_dia.jpg
