Erratic Idle At Startup
Best Answer kommander , 05 February 2020 - 11:01 PM
Turned out to be the crank angle sensor. Go to the full post
4 replies to this topic
#1 kommander
kommander
  • 210 posts
Posted 03 August 2017 - 02:07 PM
My Jap Spec SPi mini has an erratic idle at startup (cold engine). This symptom however, disappears once the engine is warm. Any attempts at driving the car before the engine is warm results in it cutting out, and having to be restarted. There's definitely a misfire. Scans with my SP hasn't returned any error codes. I have replaced plugs, leads and coil. There's a K&N filter installed and the injector seems to be spraying fine.
The coolant temperature sensor was replaced last year.
The following are vids I made at startup
https://youtu.be/1d72EWVp6R8
https://youtu.be/OCfHw4XaMss
Any suggestions will be appreciated.
#2 BlakeSarrington85
BlakeSarrington85
  • 21 posts
Posted 08 August 2017 - 12:36 PM
on a typical ecu when the engine is cold it runs on closed loop settings which are set by factory. the car takes no readings from sensors apart from coolant temperature. once the coolant reaches a certain temperature it will move onto open loop circuit which will give the ecu readings from things like air temperature,O2 sensors and throttle position sensors etc. they will adjust accordingly to engine temperature, ambient temeraturte etc. typically on closed loop a car will run fast idle to gewt heat in the engine quicker. hope this gives you slightly better understanding.
Edited by BlakeSarrington85, 08 August 2017 - 12:38 PM.
#3 bigchief3679
bigchief3679
  • 228 posts
  • Local Club: trinimini
Posted 23 November 2017 - 12:24 AM
Was this sorted? It may likely be the ceramic manifold heater at the base of the intake manifold or its wiring.
#4 pete l
pete l
  • 1,358 posts
Posted 12 March 2018 - 01:40 PM
Is the MPI the same ?  I ask because mine is very hard to start and runs like a pig from the word go.
#5 kommander
kommander
  • 210 posts
Posted 05 February 2020 - 11:01 PM   Best Answer
