Hi, as the title says, I'm in the process of putting the interior back in the car and I'm wondering do I glue the dash to the rail when refitting ?
It appears to have been bonded previously
Tia jim
Fitting Lower Dash Rail
Jimbob98
, Aug 03 2017 08:52 PM
3 replies to this topic
Posted 03 August 2017 - 08:52 PM
Posted 03 August 2017 - 09:14 PM
It should hook over the top, wrap round the underside and secure in with the switch panel and some screws in from the underside into spire clips either end
Posted 03 August 2017 - 09:17 PM
Thanks very much that makes sense.
Jim
Jim
Posted 03 August 2017 - 09:29 PM
The lower dash pad is usually stuck down with a bit of adhesive at either end. The switch panel will fairly hold the middle in.
Don’t go to mad with the adhesive in case the pad needs to come out in the future again.
