Mini Mayfair 998cc
Mot until May 2018 with no advisories
53k miles
Bodywork is in good condition with a flew blemishes: rust patch as pictured, few small dents in roof but not damaged paint, there is a small bit of rust under the one sticker also
Interior has a very good condition equinox interior with no tears
3 dial speedo
Carbon effect dash
Alloy gear knob and handbrake
Everything works as it should
In the process of fitting a stereo
Engine has had a lot spent on it:
Most recently had a carb rebuild and set up by Carbcare (as seen on car s.o.s)
Electronic ignition replaced points
New alternator
Stage 1 exhaust system fitted
Polybush engine steadys
New fuse box fitted
Easy removable grille
Recently replaced petrol hose
Stainless radiator and silicon hose set up
Tiny oil leak
New Dunlop D1 alloys worth around £450 alone, if I don't get the offer I want I will be removing and putting some minilites on
Uprated headlights also
£3700
Px considered
07496095375
Edited by smithy3793, 11 August 2017 - 12:55 PM.
