Starting Issues 1980
Posted 13 August 2017 - 09:06 AM
Cheers in advanced
Posted 13 August 2017 - 10:39 AM
The battery; stood it also still during six years? Than you could have the tension (12V) but not the current (amp).
When you have a fresh battery, checque the connection of the earthline from the battery to the bottom of the boot.
Are you sure there is no rust there, not any. And the bolt that holds the wire to the bottom is tight?
The current has to go round and round.
Posted 13 August 2017 - 11:42 AM
Posted 13 August 2017 - 04:18 PM
Posted 13 August 2017 - 04:19 PM
Posted 13 August 2017 - 04:38 PM
Posted 14 August 2017 - 12:07 AM
How old is the fuel?
Posted 14 August 2017 - 10:54 AM
"New aerth straps". There was no paint where you bolted them down. Both contact surfaces were totally blank? And the eyes of the battery cables are blank inside too?
Posted 14 August 2017 - 10:59 AM
I'm going to go with muck in the carb.
Posted 14 August 2017 - 01:55 PM
Ok so i checked
1- earth straps , both new ish and clean contacted area
2 - battery is fully charged
3 -pulled all plugs cleaned and re checked gap - all seem fine
4 - tried checking 2 of HT lead for spark - no spark but unsure if im doing correctly !!!!!
5- fuel is only 3 weeks old
how do i check for correct spark andor clean the carb ?
cheers
Jay
Posted 14 August 2017 - 06:42 PM
Posted 15 August 2017 - 04:54 PM
"just won't tick over"
I understood that he starter motor does not turn the crankshaft. Am I wrong?
Posted 15 August 2017 - 05:29 PM
Posted 16 August 2017 - 02:43 PM
It's not my mother's tongue, obviously.
Posted 17 August 2017 - 06:24 AM
i got volts to the coil , it might be the ignition module
